 Error with W49F002U all TopWin English :(
Macgaiver
Posted - 11/14/2006 :  20:39:38  Show Profile
Hello, I hope somebody has a solution for this problem.
When trying to program the component Winbond 49F002U with TopWin English v2.33.
when arriving in the address 6000 i get a error :(
if I use TopWin v2.29 Chinesen with the same component it records with totality. Because?
I tested with other versions this is the only that it records this component is TopWin Chinese v2.29;)
Some idea of when they will be solved this? My tape recorder is a TOP2048;)
Thankful!
Here my image for TopWin 2.33
And here the correct record ;)
Edited by - Macgaiver on 05/07/2007 15:56:35
nunovti
Posted - 12/11/2006 :  22:11:10  Show Profile
can u give that version? i'm having similar problems
Macgaiver
Posted - 04/09/2007 :  06:35:39  Show Profile
Today it is day 09/04/07, the version of the TopWin English or Chinese
is in v2.35, and so far the problem continues in the same way and
without solution: (
Edited by - Macgaiver on 05/07/2007 15:56:57
nunovti
Posted - 04/15/2007 :  11:16:57  Show Profile
posta a versao 2.29
Macgaiver
Posted - 04/25/2007 :  16:26:11  Show Profile
Opa você ainda que a versão 2.29 ?
homebrew05
Posted - 05/06/2007 :  21:56:17  Show Profile
I found your Topics of problems with TOP2048 for
W49F002U.
Has the problem been solved already?
I am having similar problems with TOP2048 for W49F002U.
It works Fine in Chinese version software only,
It has problem in writing process using any English version.
>it records this component is TopWin "Korea" v2.29,
you wrote.
I would like to replace the description "Korea" with Chinese.
If that problem has been solved already,
Please advise some ideas,
Macgaiver
Posted - 05/07/2007 :  14:59:34  Show Profile
Unhappyly it was still not solved in the current versions.
In case v2.37 in my case
Still I follow the use of program in "Chinese" version 2.29 ;)
Sure!!
Edited by - Macgaiver on 05/07/2007 16:03:12
homebrew05
Posted - 05/07/2007 :  16:26:42  Show Profile
Thank you for your reply.
So If the copyright is permitted or within a copyright I will try to convert it from chinese .EXE to English .EXE with Difficult wall in my poor skill .
I began to think that manufacturing should improve this problem early.
