 SST49LF004B Tsop40 no ID
sylverster16v
Germany
Posted - 06/23/2011 :  09:19:36  Show Profile  Reply with Quote
hi,
i have gq-4x fwh/lpc+ v2 adapter and 2 chips tsop40.
both chips are from running systems but i cant get id.
there is no tsop40 settings only tsop32 in the config.
please help
sylverster16v
Germany
Posted - 06/24/2011 :  12:25:55  Show Profile  Reply with Quote
datasheet:
www.datasheets.org.uk/pdf/getfile.php?dir=Datasheets-35&file=DSA-688328.pdf&scan=
sylverster16v
Germany
Posted - 06/24/2011 :  15:45:37  Show Profile  Reply with Quote
tried every speed to erase and blankcheck,but evertime blankcheck stops with 34%
Posted - 06/25/2011 :  22:56:13  Show Profile  Reply with Quote
which adapter you used then?
sylverster16v
Germany
Posted - 06/26/2011 :  04:58:23  Show Profile  Reply with Quote
i used ADP-071 TSOP32 TSOP40 FWH/LPC+ base board
and
ADP-077 TSOP 20mm adapter set top ZIF board on it.
the id is fffff
i have also the fwh/lpc+ v2.1 but there is no dip socket on it,only the holes.
Edited by - sylverster16v on 06/26/2011 05:06:01
sylverster16v
Germany
Posted - 06/28/2011 :  13:50:35  Show Profile  Reply with Quote
no idea?
Posted - 06/29/2011 :  18:18:16  Show Profile  Reply with Quote
Adapters are correct. Make sure all three jumpers on the ADP-071 are set.
If the chip is good, then the problem maybe on the adapter. Check all pin contact.
Foul
France
Posted - 12/02/2011 :  12:53:02  Show Profile  Reply with Quote
up !
Exactly the same prob .. tested with 2 differents chips ..
On searching this forums ... many users have the same probs ... any update planned ?
Thank you !
www.jamma.fr
