 W29EE512 problem erasing and flashing
jammie
Posted - 06/20/2013 :  05:25:01  Show Profile
i need to flash some w29ee512 chips with a latest firmware for some scsi to ide cards
im using the willem pcb50b programmer
i use the plcc32 socket i can read the chips but cant verify or erase or flash them
i check the software protect switch to unprotect them
but get errors when trying to do other functions
if i do the id the manufacturer does not come up
or its id
is there a programmer that can identify the chip and do the correct
hardware unprotect 3 byte instruction so that htey can be erased and flashed with the latest firmware
any help would be great
and whats the best programmer for me as i also have a load of 27c040 chips to burn
Posted - 07/06/2013 :  17:44:29  Show Profile
GQ-4X
smf_
Sweden
Posted - 12/05/2015 :  11:30:35  Show Profile
Did you ever solve your problem? I'm facing the same problem ATM :) i have a willem pcb 50
