 Top 2004 and Windows Vista
channelmaniac
Posted - 04/02/2007 :  11:32:48  Show Profile
Hrmmm...
I get the dreaded "A service installation section in this INF is invalid." and the driver refuses to load.
Are there any workarounds for this or am I doomed to wait for a Vista driver?
Thanks,
RJ
channelmaniac
Posted - 04/22/2007 :  20:55:42  Show Profile
OK...
Got the drivers to load... but it won't "see" that it's loaded... dangit...
Here are the changes I made to the .inf files to get this far...
Enjoy!
RJ
Change the following in topwin.inf
Change: ServiceBinary = %10%\System32\Drivers\windrvr6.sys
To: ServiceBinary = %12%\System32\Drivers\windrvr6.sys
Change: DefaultDestDir=10, System32\Drivers
To: DefaultDestDir=12, System32\Drivers
Change: 1="TY51 Installation Disk",,
To: ;1="TY51 Installation Disk",,
Add this line to the [SourceDisksFiles] section:
windrvr6.sys=c:\top\topwinen\driver
Change the following in windrvr6.inf
Change: DefaultDestDir=10,System32\Drivers
To: DefaultDestDir=12,System32\Drivers
Change: 1=%INSTDISK%,,,.
To: ;1=%INSTDISK%,,,.
Change: ServiceBinary=%10%\system32\drivers\windrvr6.sys
To: ServiceBinary=%12%\system32\drivers\windrvr6.sys
Change: windrvr6.sys=1
To: ;windrvr6.sys=1
Add the following line to the [SourceDisksFiles] section:
channelmaniac
Posted - 04/22/2007 :  21:01:23  Show Profile
This is frustrating... I've set compatibility mode on Vista... and have granted the app "run as administrator" privileges...
All I get is "Driver not ready,if load it now?"
What a PITA.
Anyone else ever get this to run successfully under Vista?
Edited by - channelmaniac on 04/22/2007 21:02:09
Posted - 04/23/2007 :  00:13:51  Show Profile
I got seem problem on Win2000. So, it is not the VISTA driver problem, it is a software bug.
I used a different version software and then it works.
try :
http://www.mcumall.com/download/all/topwinen1.44.zip
Install this version under different directory and try.
ericko
Mexico
Posted - 05/01/2007 :  21:31:34  Show Profile
I tried TopWinEn v1.44 under Vista, but the installer doesn't even opens.
Anyone has find a solution?
Posted - 05/03/2007 :  07:19:14  Show Profile
Install 1.44 on other NOT vista computer, and then copy whole directory to Vista.
muvel
Posted - 09/16/2007 :  04:54:41  Show Profile
All,
I manually copied the windrvr6.sys to ..\system32\drivers\ folder and
driver gets successfully installed. What's really missing now is
WinDriver driver installation. For some reason the version supplied with the install kit is not getting loaded or activated.
Anyone figured out a fix for this issue?
mraju
pic
Posted - 11/13/2007 :  11:21:23  Show Profile
hi am kez . im wanting o get the top 2004 or 2005 programmer im new to pic prog but these are nicely priced and will prog millions of different pic ect which is the best model and will i have the same probs runing on crapy vista thanks
Posted - 11/15/2007 :  01:17:16  Show Profile
The TOP programmer currently does not work on Vista yet.
pmcleod
Posted - 03/22/2008 :  11:23:44  Show Profile
Is there any progress on getting topwin to work with vista yet?
Peter McLeod
SUB
France
Posted - 09/08/2011 :  08:17:05  Show Profile
Hi, Drivers for Vista (x86&x64) here : h**p://drivers.spi-tech.info/
i know they are not perfect but working on vista & WIN7 32&64bits
More information in the comment here : h**p://blog.savel.org/2007/05/13/top2004-programmer-review/
sub
