 Constant write errors
Satashi26
Posted - 10/26/2015 :  11:33:05  Show Profile  Reply with Quote
I've tried 10 different EPROMs (M27C322) and 5 different filed, every single one had a write fail. I'm at my wits end trying to figure out why. Using adapter for the 42 pins
Brand new programmer/adapter. Installed software/USB drivers. Windows 7. Start up, put in adapter, put in EPROM, blank check, all good.
Chose file, click write, get to 50%ish and write fail.
Disabled Data execution prevention for it. Tried writing at lower speeds. Still failing.
EDIT: now they write 100% but fail at verify at 50%, where it used to write fail...
Any help would be VERY well appreciated.
Edited by - Satashi26 on 10/26/2015 12:47:12
Posted - 10/27/2015 :  13:08:23  Show Profile  Reply with Quote
If it fails on exact 50% address 200000, then it must be address jumper not set on 27C322 position.
Check jumper J1.
