 GQ-4X and ADP-054 no longer working
sammargh
Posted - 03/19/2018 :  16:03:48  Show Profile  Reply with Quote
My ADP-054 was working fine earlier today however now it refuses to get past 3% on 27C400 it's always the same address and the write is off by 8. I am using a power supply with the GQ-4X and as stated it worked earlier today, I was able to program about 24 chips without issue. Blank checking works fine but writing does not.
Some examples:
Chip is blank
ID check skipped
Writing... Buffer
Elapsed time: 2.34 seconds.
Write failed, Address=0x00402D, Buffer=0xEB Device=0xE3
Write failed
And with a smaller chip - HN27C4096
Write failed, Address=0x00000B, Buffer=0x88 Device=0x80
Write failed
Different file but HN27C4096
Write failed, Address=0x000003, Buffer=0x0B Device=0x03
Write failed
I know it isn't the chips because I tried almost 20 different 27C400 and all failed at the same exact address writing after passing a blank check. I was able to program the HN27C4096 with my cheap chinese TL866 fine.
Any ideas what may be going on? J1 is set to the first position.
Posted - 03/21/2018 :  04:18:11  Show Profile  Reply with Quote
Some examples:
Chip is blank
ID check skipped
Writing... Buffer
Write failed
Write failed
Write failed
Defective or dirty socket?
