 GQ-4x Gives error after update to 6.17
Kutche.net Posted - 11/05/2012 : 14:08:56
Ugh... I am running windowz 7 Ultimate
I downloaded update hopiung to see some new chips I requested quite a while back.. after update I restarted PC and i get the following error
The Class X24C00 is not found.
Parse "device list" Erro on Device x24c00P
Any ideas how to get this working again...
I am desperate.....
Jerry N9LYA
CoindoorDave Posted - 11/08/2012 : 16:32:17
THANK YOU - that did it.
ZLM Posted - 11/07/2012 : 19:45:36
The problem is the old version uninstall is not completed.
The new installation only installed the devices.txt, but not the main USBprg.exe application, since the old .exe file still there. You can confirm it bay run the software.
You can uninstall the software and manually check if the application directory is empty. You can delete the old file manually if it does not uninstall.
Once you confirmed the old application is completly gone, then install the new software.
Run the new software you should see the new version on start up screen.
Bad_Ad84 Posted - 11/07/2012 : 00:56:46
open devices.txt, do a search for X24C00 and remove all entries that contain that class. save and should work
