 voltage diagnostic fail
craig6928 Posted - 02/08/2013 : 06:20:41
hello can anyone help us out with a issue i got with a GQ-4X programmer.
it been sent back from mcumall to say its been modified
but its the same issue as before.
also the programmer is one day out of warranty
i paid nearly $70 dollars for delivery cost
the issue im having is that it failing on hardware and voltage diagnostic
so no chips can read in
i have re-downloaded the software and usb software
i tried different leads and also connected up another power unit
and as i last resort loaded up on another pc system
but it still remains faulty
below is the error
any help on this would be great
Please remove any chip from the ZIF socket!
* Testing VCC Without Load *
VCC 3.6V test failed, too low (code:0x33)
VCC 5V test failed, too low (code:0x43)
VCC 5.5V test passed (code:0x43)-
VCC 6.2V test failed, too low (code:0x6a)
VCC 6.5V test failed, too low (code:0xb2)
* Testing VPP Without Load *
VPP 3.6V/5V test passed (code:0x5)-
VPP 12V test passed (code:0x5)+
VPP 12.7V test passed (code:0x5)+
VPP 15V test passed (code:0x0)-
VPP 21V test passed (code:0xe)-
VPP 25V test passed (code:0x2)-
* Test Completed *
ZLM Posted - 02/11/2013 : 11:00:10
Looks like some problem with your hardware.
craig6928 Posted - 02/11/2013 : 06:58:22
first photo is the id check error
h**p://imageshack.us/photo/my-images/28/snap20130211143909002id.png
second photo is of what version of programmer
h**p://imageshack.us/photo/my-images/94/photoofprogrammerandsof.png
third photo is the voltage check fail
h**p://imageshack.us/photo/my-images/23/photooftesthardwarevolt.png
i have tried and downloaded the older version same thing
craig6928 Posted - 02/11/2013 : 06:19:18
this is the message i get
ID CHECK FAILED ("290000")
PLEASE CHECK DEVICE TYPE CHIPS ORIENTATION AND PIN CONTACT
SOME OEM CHIPS MAY HAVE COMPATIBLE CHIP ID CONTINUE
WHEN WRITE TO CHIP THE SAME MESSAGE COMES UP AGAIN
and also it looks like it erases the chip
Some OEM chips may have compatible chip ID
Continue?
Yes
ID check skipped
Writing... Code
Elapsed time: 40.59 seconds.
Device write completed OK
ID check failed.("290000")
Please check device type, chip's orientation and pin contact.
Continue?
Yes
ID check skipped
Writing... Data
Elapsed time: 0.01 seconds.
Continue?
Yes
ID check skipped
Writing... User ID
Elapsed time: 0.00 seconds.
Continue?
Yes
ID check skipped
Verifying... Code
Verify Failed, Address=0x000002, Device=0x00, Buffer=0x2A
Verify Failed
Elapsed time: 2.24 seconds.
CHECK DATA ON CHIP
Continue?
Yes
ID check skipped
Verifying... Code
Verify Failed
Elapsed time: 2.90 seconds.
craig6928 Posted - 02/11/2013 : 06:18:28
when i got the programmer it was working 100%
but as it always ask you to download new version
this is where the issues started.
i need mcumall to sort this out for us :(
craig6928 Posted - 02/10/2013 : 20:50:02
hello ZLM
i tried that version also
when you reset the programmer it read outs are different every time
in the voltages
i selected the pic16f872 to program
when i go to the voltage test it the same errors that comes up
with out this i can not program any pics
i got other programmers but they can only read hex files
and where all my files are bin.
is there a way to read them in the pickit 3 ?
or convert them direct to hex
any advice be great
thanks
ZLM Posted - 02/08/2013 : 20:57:16
There is a software bug in Re6.20 when testing the voltage.
The bug causes voltage testing fail if no device selected. But if device is selected, then the voltage testing will be fine.
Try this Re.6.21 version:
http://www.mcumall.com/download/TrueUSBWillem/USBPrgSetup6.21.exe
