 GQ4X PROGRAMMER FAIL VOLTAGE CHECK BRAND NEW UNIT
craig6928 Posted - 03/05/2013 : 16:28:50
ok can someone help us out with this GQ4X programmer
went out and bought new one
and this worked to begin with and now the bug has transfer over
to the new programmer and give the same fault on voltage errors
can anyone try and do a voltage check on a pic16f872
and report back if you had a error on voltage check
and what version of firmware your using and software
Ready
H/W Re: GQ-4X Re-2.10
USB Driver Re.2.0
Software Re. 6.00
DEVICE
Device not found!
Load
Please download new software from server
* Testing VCC Without Load *
VCC 3.6V test failed, too high (code:0x24a)
VCC 5V test failed, too high (code:0x192)
VCC 5.5V test failed, too high (code:0x15f)
VCC 6.2V test failed, too high (code:0xff)
VCC 6.5V test failed, too high (code:0xff)
* Testing VPP Without Load *
VPP 3.6V/5V test failed, too high (code:0x375)
VPP 12V test failed, too high (code:0x272)
VPP 12.7V test failed, too high (code:0x252)
VPP 15V test failed, too high (code:0x211)
VPP 21V test failed, too high (code:0x14d)
VPP 25V test failed, too high (code:0xdc)
* Test Completed *
this also looks like mcumall know about this bug
but wont own up to it
so a new programmer worked great then back to the same error
some how it transfer the update of the old programmer with the bug
craig6928 Posted - 03/13/2013 : 20:07:32
finally they fixed the programmer software that had big problems
no more voltage error its correct now
the voltage check helps us out a lot and its useful
going to stick with the latest software as there no need to upgrade unless there more tools
thank you to all the members on the forum and especially you ZLM
and mcumall for helping us out
ZLM Posted - 03/06/2013 : 20:21:04
download the latest software and try. It fixed a voltage testing bug.
Bad_Ad84 Posted - 03/06/2013 : 13:41:37
IIRC, you dont do the voltage checks with the chip in. But its been awhile since I owned a GQ-4X, but throwing about baseless accusations isnt exactly helpful
