 Error: Address exceed range
willyarma Posted - 04/26/2017 : 13:05:19
I have a GQ-3X and a ADP-042 and have been trying to read an SST39VF6402
(which is a 64 megabit device) but am getting the error "address exceed range" at 50%.
It does this with or without the adapter inserted, so anyone can try it as a test.
Ive tried it under windows 10 64 bit with signed drivers and under windows xp with unsigned drivers, both give the same error.
If I try and read an S29GL064N90TFI040 (with no adapter and chip inserted as I dont have this chip or the 8-bit adapter) which is also a 64 megabit device it works fine.
willyarma Posted - 05/17/2017 : 08:50:13
That device is there by default.
Please try it for yourself!
ZLM Posted - 05/14/2017 : 09:47:21
This message show up if you are trying to write the data to a location that exceeds the maximum address of the chip.
The problem may be caused by the device line in devices.txt
willyarma Posted - 05/13/2017 : 02:12:33
I think its a bug in the software, would anyone else be able to try it for me?
willyarma Posted - 04/27/2017 : 05:48:36
Yes they are
anniel Posted - 04/27/2017 : 02:59:12
Are the address lines A19 A20 A21 connected correctly?
