 GQ-4X support for TC58NVG3S0FTA00
JLaw Posted - 06/02/2018 : 19:29:30
Does the GQ-4X (Re-2.20) support TC58NVG3S0FTA00 (TSOP-48)? If yes, then what adapter is needed? If no, then programmer suggestions?
h**p://www.alldatasheet.com/view.jsp?Searchword=TC58NVG3S0FTA00
anniel Posted - 06/20/2018 : 03:37:05
Originally posted by laptech
This is the adapter you would have needed for the GQ
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3102
You are correct.
laptech Posted - 06/13/2018 : 06:18:36
JLaw Posted - 06/06/2018 : 13:32:40
I purchased a FlashcatUSB xPort, with a TSOP48 (Type-B) adapter for about $50. I suspect it will be a bit slow, but it should get the job done. Also, presales support from Embedded Computers was excellent.
h**p://www.embeddedcomputers.net/products/FlashcatUSB_xPort/
JLaw Posted - 06/04/2018 : 19:28:32
Here's a pic of the chip:
26869 bytes
If support for this chip is unknown, but possible, then which adapter would it be best to try with?
