 Windows 7 problem
racalpe
Posted - 10/09/2022 :  00:54:46  Show Profile  Reply with Quote
Hello everyone, for years I have been using the x4 in Windows XP sp3 and perfect, I migrated to Windows 7 and since then I cannot use it, I start the program and when I plug in the programmer it freezes and until I remove it the program does not respond. To say that I have tried everything you mention here and nothing... Also in virtualbox with xp sp3 the program does not even open for me, it opens a window that it has found an error and must be closed. My questions are: any solution for Windows 7 to freeze? Xp sp3 in virtualbox that you need to have installed for it to boot? It is very inconvenient for me to change the hard drive on the laptop to be able to use the programmer..... Thanks and regards
I edit to say that 3 different laptop brands and same result....
Edited by - racalpe on 10/09/2022 01:03:43
Posted - 10/09/2022 :  10:31:42  Show Profile  Reply with Quote
Try this: http://www.mcumall.com/downloads/download.asp?DownloadID=56
racalpe
Posted - 10/09/2022 :  14:34:11  Show Profile  Reply with Quote
Hello, thank you for responding but my programmer is the old version (USB GQ-4X) and it doesn't work with driver 3.0.....
Posted - 10/10/2022 :  07:18:52  Show Profile  Reply with Quote
Ok, in your first message you stated X4.
Try this then: http://www.mcumall.com/downloads/download.asp?DownloadID=59
