 GQ-4x4 16 bit adapted canot read PLCC32
Ronen 722
Posted - 09/21/2023 :  13:17:52  Show Profile  Reply with Quote
Hi All, I hope you can help.
I am trying to read the chips from MSA15 ECU 074 906 021 F with the 16 bit adapter plugged in the GQ but is does not give a good read.
I inser the chip in the lower socket on the right side of thwe adapter, select device, insert 29f400b from the flash lookup, I do the ID and get unknown deivce. I then read one chip and get the buffer code. save the file, load to winols but the file cant be read.
Any help please ?
Posted - 09/23/2023 :  07:56:00  Show Profile  Reply with Quote
Any help please ?
The 29F400B doesn't require a 16 bit adapter.
