 MX29F1615 Error writing
pierpa86
Posted - 11/03/2024 :  08:12:59  Show Profile  Reply with Quote
I'm trying to write a file on my MX29F1615 but its always fail
Write failed, Address=0x005540, Buffer=0xFF Device=0xFF
-Done same test with 10 other eprom and same error.
If i change file with any other there is no problem, its working fine.
After a lot of test its seems a file problem.
something in this file causes the writing process to go wrong.
Bug of adapter ?
Bug on programmer software ?
https://ibb.co/82wYNSd
Edited by - pierpa86 on 11/03/2024 10:13:18
pierpa86
Posted - 11/03/2024 :  08:15:51  Show Profile  Reply with Quote
I cut the file, eliminated the part where I always had the problem and it continues to work, it seems that something inside this file doesn't like it and is sending the programmer into error.
pierpa86
Posted - 11/03/2024 :  08:30:19  Show Profile  Reply with Quote
Write failed, Address=0x005740, Buffer=0xFF Device=0xFF
Write failed
pierpa86
Posted - 11/03/2024 :  08:44:07  Show Profile  Reply with Quote
Done another test, writing on C322 and its work fine.
So the problem it on this file and this MX29F1615
pierpa86
Posted - 11/05/2024 :  05:28:34  Show Profile  Reply with Quote
This is the Official support forum ?
Can i ask support here ?
Posted - 11/05/2024 :  08:00:05  Show Profile  Reply with Quote
Originally posted by pierpa86
Bug of adapter ?
Your picture doesn't show the right address.
Posted - 11/05/2024 :  08:01:48  Show Profile  Reply with Quote
Why would you think the file would have any effect on the programmer?
Posted - 11/05/2024 :  08:03:01  Show Profile  Reply with Quote
Write failed
Why did the address changed?
Posted - 11/05/2024 :  08:04:00  Show Profile  Reply with Quote
Looks like you have bad or fake chips.
pierpa86
Posted - 11/05/2024 :  13:02:51  Show Profile  Reply with Quote
Because the problem arises only if I use that file, I also thought it was an eeprom problem but I get the same error on the same address every time I use this file, if instead I change files on the same bank if I try to write any other file, it works fully . I have 40 eeproms available and for now they all work, I can't write just this file.
does anyone want to try this eeprom model? do you want me to share the file?
pierpa86
Posted - 11/05/2024 :  13:12:02  Show Profile  Reply with Quote
Here you are, please test it with a MX29F1615
https://we.tl/t-4rdL7iXVTJ
https://ibb.co/TYxs6Xr
Here the error, a new try for you.
Always fail at the same address
https://ibb.co/bF5Ff6F
Edited by - pierpa86 on 11/05/2024 13:15:47
pierpa86
Posted - 11/06/2024 :  06:10:54  Show Profile  Reply with Quote
Some progress, as i say the problem occur only if i write that file on MX29F1615
But today i completed my new adapter from Ptchnk project and its working fine
c:\users\muc\desktop\**\**\**\c2.part1.
ID check OK
Erasing...
Elapsed time: 16.17 seconds.
Erase completed.
Blank checking... Buffer
Elapsed time: 24.78 seconds.
Chip is blank
Writing... Buffer
Elapsed time: 194.52 seconds.
Device write completed OK
Verifying... Buffer
Device is verified
So the problem is on original adapter.
But since the same file can be written of a different memories, tested on 27c160 and 27c322, where is located the problem ?
Bug on adapter schematic ? Is that the last version ? ADP-054 v4.1
Seems not broken if can write the same buffer data on a 27c160.
Tell me what you think about guys.
https://ibb.co/z7H8vC9
Edited by - pierpa86 on 11/06/2024 06:12:57
pierpa86
Posted - 11/07/2024 :  02:48:38  Show Profile  Reply with Quote
Guys i need official supporto to understand quickly the problem, if the problem is on the adapter i can send it back to GQ Elettronics UK Europe on Amazon
Otherwise tell me please.
pierpa86
Posted - 11/20/2024 :  10:16:59  Show Profile  Reply with Quote
I solved it by giving this programmer back and buying a better one Xgecu T56, a little more money but at least I have control of the PINs which avoids a random writing failure due to a bad contact and without an adapter for the dip42.
Software is up to date and its support more dip42 chip.
