 PIC18F2420 Configuration Bits Not Read In
motc
Posted - 05/08/2026 :  20:10:06  Show Profile  Reply with Quote
I have a HEX file that is used to program a PIC18F2420. When read in by USBPrg 6.39 the fields in the Configuration tab are populated correctly, as the configuration information is in the HEX file. When the same file is read into USBPrg 7.40, the fields in the Configuration tab don't change at all. Furthermore, the method to change the fields in 7.40 appears to be faulty or have shortcomings, since it can't replicate the exact values I get automatically in 6.39 by forcibly choosing items from the combo boxes because I can't directly enter the corresponding hex values. Why this regression? Is there a way to bring in the values that were in the input file all along without having to enter them manually? My programmer is a GQ-4X V4 and I have USBPrg 7.40. A colleague has a GQ-3X and runs USBPrg 6.39. He is able to program the PIC18F2420 without any issues and I cannot, despite having a newer device with more recent software.
Posted - 05/09/2026 :  05:15:25  Show Profile  Reply with Quote
Ask your colleague for the PIC18F2420 device line he is using and add it to your customdevices.txt or devices.txt.
motc
Posted - 05/09/2026 :  06:28:15  Show Profile  Reply with Quote
Thanks for your advice. I'm not sure why an earlier version of the software would have an improved entry in the devices.txt file or how it would make the software work more comprehensively. Here are mine for version 7.40.
$ grep PIC18F2420 *.txt
devices.txt:Name="PIC18F2420*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",PINVCC="ZIF32_PIN28";
devices.txt:Name="PIC18F2420*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+";
supportedList.txt:PIC18F2420*DIP28,,
supportedList.txt:PIC18F2420*ICSP(Adadper:ICSP/PIC adapter+),,
motc
Posted - 05/09/2026 :  17:04:41  Show Profile  Reply with Quote
By uninstalling the latest version, rebooting, reinstalling the latest version and rebooting again, I was able to get USBPrg to read in and populate the PIC18F2420 configuration bits. Erasing and writing resulted in a PIC that worked in the circuit as expected. Not sure which of the above steps was responsible for straightening things out, but as long as it works I'm pleased.
Posted - 05/11/2026 :  05:40:36  Show Profile  Reply with Quote
That looks ok.
Posted - 05/11/2026 :  05:40:44  Show Profile  Reply with Quote
Looks like your install was somehow corrupt.
