 AMIC in GQ-4
yelenavik
Posted - 03/17/2009 :  18:07:11  Show Profile
Hello,could You add Amic A29L040L-70,because show ID failed,get ID # 3792,but anyway can read but cant erase go to 45% then failed.Thank's.
Posted - 03/18/2009 :  08:11:51  Show Profile
Add this line to devices.txt:
Name="A29L040",ID="3792",Class="29F040B",Category="FLASH",,VCC="3.6V",MFG="AMIC";
yelenavik
Posted - 03/19/2009 :  12:53:04  Show Profile
Thank's ZLM.Now check ID ok I can read,erase,even write but verified failed not depend from speed.(I unprotect before operation).May be need external power suply?
Posted - 03/19/2009 :  20:21:58  Show Profile
Not the power supply issue.
Did you do the blank check after erase? this will check if the erase works.
Does the chip protected?
Do you have second chip for testing?
Is it used chip or new chip?
How do you know the chip is not the bad chip?
yelenavik
Posted - 03/19/2009 :  20:55:49  Show Profile
Yes chip blank ok,about protected i dont know.I have 2 chips used.second same .I dont know good chips or bad.
Posted - 03/19/2009 :  22:24:12  Show Profile
Does the chip is blank initailly? or the erase works?
yelenavik
Posted - 03/20/2009 :  03:36:50  Show Profile
yes erase work, all FF.
yelenavik
Posted - 03/20/2009 :  22:45:44  Show Profile
Every time different address,it s may be bad connection in PLCC-32,I will try clean later pins of chip
Posted - 03/20/2009 :  23:10:02  Show Profile
Barely put the chip in the socket, this will help the pin contacting.
sucuka
Hungary
Posted - 08/17/2013 :  02:56:26  Show Profile
Hi!
I trying a reprogram a BIOS chip of FSC Amilo Pi 1536 notebook. The chip is AMIC A29L800ATV, but this chip is not in the devices.txt. I select this device for program (based on datasheets): AMD AM29F800T and ignore "ID-check" and Jumper leave in the 3V position! The chip is programmed and verified successfully, and the notebook is working properly.
ZLM: Please verify this line, if its correct, please add the devices.txt in next version of GQ-program.
Name="A29L800ATV",ID="371A",Class="29F800T",Category="FLASH",MFG="AMIC",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="3V";
Pictures:
131.14 KB
125.89 KB
145.94 KB
Rgds!
Creator of Hungarian Language of GQ-USBPrg.
Posted - 08/17/2013 :  22:22:39  Show Profile
Great job.
Thank you. We will put this device into next software supported list.
Please let me know what adapter you used.
