 SST25VF080B programming with GQ-4x
craul33
Posted - 07/20/2009 :  21:18:04  Show Profile
I have an GQ-4X programming tool and I want to read /whrite the SST25VF080B .I am selecting the SST25VF080B from the list (normal mode or slow mode) and I canot check the ID of the flash and what I read from flash is only ooooooo or fffffff . If I select fom the begining of the list 25c080 , is correct to red information from flash but only 1% can be read with this selection ... I tell is correct because is displayed some "award bios 2003 ...bla...bla...bla" I did not use the SOIC8-DIP or WSON8-DIP adapter because I don't have it .. I am using some hand made adapter .I put him (SST25VF080B) asa the same way like 25c080 , that mean down in the socket with the key up . Please Help me .. Thank you very much
Posted - 07/22/2009 :  15:23:38  Show Profile
If you can read it by 25C080, then it should be read with 25VF080B. Check your adapter contact with programmer. Or your chip is dead if you can confirm all connection and contacting are good.
