 TOP2003 doesn't like XP
RT
Posted - 09/02/2004 :  03:11:04  Show Profile
Hello all,
Just installed my new TOP2003 programmer. The first time that I run the software, everything works fine, but on the next startup, I get the error "EAccessViolation".
At this point the only way to make it work again is to uninstall software and cypress ezusb driver and start from scratch. then it will work one more time.
OS is Win XP pro SP1, running on a 3 gHz P4 with 768mB.
Aside from the USB driver annoyance, it works very well.
I have tested it with several EPROM's, 2 EEROM's, 3 Atmel mcu's, 2 PIC mcu's, and a 16v8 PAL. All worked perfectly.
Is there hope of a driver fix any time soon?
someone
Posted - 09/06/2004 :  09:25:06  Show Profile
You may need try install the software without patch software. If it works then that may be the a software bug of patch. And you need ask www.mcumall.com for latest patch software.
If possiable, try different software release. It may give you some answers.
Edited by - someone on 09/06/2004 09:26:11
