 SST28SF040A 32-pin chip in GQ-4X
stayouttadabunker
Posted - 09/06/2010 :  09:11:25  Show Profile
I noticed the SST28SF040A 32-pin chip is not
listed in my "devices" listing in my GQ-4X programmer.
I love my programmer by the way!!!
Is there a "device" setting I can use that would work for this chip?
Thank you very much for any help you can give me on this!
-Bunker
26.05 KB
Edited by - stayouttadabunker on 09/06/2010 09:13:08
Posted - 09/06/2010 :  19:37:43  Show Profile
Try to add devices line into devices.txt:
Name="SST28SF040A",ID="BF04",Class="AT29C040A",Category="FLASH",MFG="SST";
Please let me know if it works.
stayouttadabunker
Posted - 09/08/2010 :  10:26:26  Show Profile
I was able to enter the device name
into the devices.txt as per instructions and it comes
up as an optional device and displayed in the dialog boxes.
However, when trying to erase,verify,or write to the chip...no go.
The programmer has no problems reading the chip -
but that's all it will perform.
Is it possible the Class of "AT29c0404A" is incorrect?
If I were to obtain a copy of this chip's specifications
and post it here - would you be able to send me a fix?
Edited by - stayouttadabunker on 09/08/2010 10:28:05
Posted - 09/10/2010 :  21:17:43  Show Profile
Can you get the chip ID?
Checked datasheet and found new software needed in order to support this chip.
If you want add this chip in, then you can send a testing chip to support@mcumall.com. You chip will be returned to you after the test.
stayouttadabunker
Posted - 09/13/2010 :  05:57:57  Show Profile
Yes,
The chip ID is: BF04
I am not sure if it's "zero" four or the letter "O" four.
I will try to attach a screen shot of the programmer's dialog box.
Thanks for your help on this.
I will search for your address and mail out the chip to ya.>>>
16.65 KB
Edited by - stayouttadabunker on 09/13/2010 06:01:00
Posted - 09/15/2010 :  08:33:39  Show Profile
ID is correct. We need a good chip to find out the problem.
