 True USB programer help with PLCC32-DIP28 Adapter
acem77
Posted - 08/27/2006 :  12:42:20  Show Profile
i am trying to program a sst 39sf020. i have 2 and both do not work so far with the programmer.
i have the the dip switches correct. it reports the chip as 5v so i left the jumper in on the adapter.
what am i missing?
the zif is locked down with the adpter at the top near the lever.
do i need to set jumper on the programmer?
i have had good luck with a handful of eproms.
Man is the best computer we can put aboard a spacecraft... and the only one that can be mass-produced with unskilled labor.
Posted - 08/28/2006 :  16:34:35  Show Profile
There are no jumpers on programmer. Only the DIP switch need to be set based on the picture in the software.
I guess that you are using a wrong adapter. The PLCC32-DIP32 adapter has no jumper on it, which you should use.
The one with voltage jumper is PLCC32-DIP28 adapter, which you should not use.
Edited by - ZLM on 08/28/2006 16:35:07
