 dual power pci parallel card not working
Shawn
Posted - 04/11/2011 :  21:19:50  Show Profile
I have purchased a new computer which of coarse has no parallel port. first I tried a parallel to usb cable with no luck(still have and would prefer to use but doesn't matter).
next I installed a pci parallel card with no luck
how can I get this thing to work
Using Willem dual power running xp pro on p.c (card) vista on lap (for cable)
Posted - 05/11/2011 :  00:04:49  Show Profile
It is hard to let it work on new computer. There are lot of things need to get configured if you add a LPT port card.
I suggest you to get GQ-4X programmer. That will be much easier for you.
Martin Baugh
Posted - 09/23/2011 :  08:21:24  Show Profile
Some of us cant afford to buy another programmer due to the recession, so their must be some way to get this to work on more modern computers.
Martin Baugh
Posted - 09/24/2011 :  02:12:11  Show Profile
For those with Windows Vista and Win 7 64 Bit this article should sort out the problem :- h**p://www.downtowndougbrown.com/2010/10/sivava-willem-eprom-programmer-on-windows-7-64-bit/.
Hope this helps.
