 programming An28F512
ludo7188
Posted - 10/31/2006 :  16:41:12  Show Profile
sorry but my English is very bad
I have an Enhanced Willem Programmer.
I want to program a chip AN28F512-120 (PLCC32).
I can read, but I can't erase ("time out")the chip, and when I want to program a new soft on the chip, I have error, for exemple: "error at 0*0000D3 Chip=0*00 buffer=0*01"...
Can you help me please...
thank
Ludo.
Posted - 11/02/2006 :  01:29:24  Show Profile
If all settings are correct, then you should be able to get the ID correctly.
The device 28F512 should be selected.
You have to erase the chip before write.
If you can not erase the chip, please check if it is a bad chip.
ludo7188
Posted - 11/02/2006 :  04:10:40  Show Profile
I can get the ID.
the chip come from on Bosch ECU. How do you check the chip?
Ludo
ludo7188
Posted - 11/06/2006 :  15:39:48  Show Profile
hello,
someone can help me please?
Ludo
ludo7188
Posted - 11/06/2006 :  17:02:35  Show Profile
hello,
the chip is an AN28F512, ID 0*02, 0*20.
I think you find the problem! on pin 1, Vpp=0V ... but now, how I can have 12V?
Thank you
Ludo
ludo7188
Posted - 11/08/2006 :  16:32:05  Show Profile
Hello,
my problem is solved!
I found this message : http://www.mcumall.com/forum/topic.asp?TOPIC_ID=93
and the LTP port BIOS setting wasn't EPP mode... now it's OK, I can read, erase and flash!
and now ID is 0*89 (intel), 0*B8.
Thank you for your assistance
Ludo
Edited by - ludo7188 on 11/08/2006 16:33:51
javiercj
Posted - 09/06/2011 :  09:35:52  Show Profile
Originally posted by ludo7188
Hello,
Ludo
hello ludo
I can to read the memory 28f512 but i dont write the memory.
the id is correct but i dont write.
i have the programmer willen gq-4x but i have not port lpt
help me
thnaks
