 Atmega88
daniel.poars
Posted - 08/23/2011 :  14:23:39  Show Profile
Hello. I recently bought a GQ-4X programmer. I'm trying to program an atmega88 20PU. First off all, I did not found it in the library, only "atmega88*isp" and "atmega88V*isp". I did all the pin connections and the power on at the chip and got nothing. I know I have to use avr isp conection. So, the only thing a need to do is conect the pins (miso, mosi etc) and power on the target right ? This chip is not new and has been already programmed before. Any help will be appreciated. Sorry my english. I'm doing the best to make you understand.
Regards.
Edited by - daniel.poars on 08/25/2011 09:06:14
Posted - 08/23/2011 :  17:03:06  Show Profile
The chip must be ISP enabled in fuse setting.
Also, the chip clock need to be set to internal. Otherwise you need a external cyrstal connedted to chip.
daniel.poars
Posted - 08/23/2011 :  20:45:51  Show Profile
Thank you for your attention. Can you give e the right configuration ? I'm using the latest version.Regards
Posted - 08/25/2011 :  10:37:11  Show Profile
Can you confrim your chip is ISP enabled?
Do you know if your chip set to use internal clock source.
daniel.poars
Posted - 08/25/2011 :  16:03:21  Show Profile
Thank you for replying this. I don't know if my chip is isp enable and I even don't know how to do this . The chip is not new. I just have connected the pins (miso, mosi, vcc, ground and reset) and tried to program. If get a new chip it will be more easy to do ? I have the configuration off the fuse bits to use with ponyprog, but a bought this GQ-4X programmer thinking it would be much more easier to do this.
Posted - 08/25/2011 :  17:10:19  Show Profile
The GQ-4X is supporting standard ISP programming.
If your chip is not in circuit, try to built up a simple circuit, include Vcc, GND, clock crystal etc.
If it still does not detect the chip, then the chip may be ISP disabled. Then you need to find a parallel programmer to enable it.
daniel.poars
Posted - 08/26/2011 :  05:50:07  Show Profile
Ok. I'll build a circuit. Thank you for helping me.
