 Mx29lv160
tahir
Posted - 04/18/2012 :  13:36:18  Show Profile
Hi could anyone help me I'm programing a mx29lv160 when I erase chip it says erase ok but fails blank check it program s ok but fails on verify but compares good is it possible the chip is faulty thanks
t.hussain
Posted - 04/20/2012 :  23:01:18  Show Profile
if blankcheck failed, then the erase is fail.
If the chip is locked, then you need to unloack the chip before write it.
Posted - 05/01/2012 :  20:14:40  Show Profile
Not sure the FlashPRo 400+. I am only know the GQ-4X. On GQ-4X, there is a unlock feature, it can unlock whole chip.
vendest
Posted - 01/15/2017 :  15:39:22  Show Profile
Hi guys, I'm new here.
Bumping on this old thread as I'm having a similar issue
Trying to program a MX29LV160TM with TOP 3100.
The program seems to be writing upon verifying the chip is still blank.
Understand from above that the eeprom could be locked/protected. Is there a way to unlock the chip from topwin7?
Thanks,
Jerome
Posted - 01/22/2017 :  18:36:28  Show Profile
Try on new chips. Brand new chip never in a locked state.
vendest
Posted - 01/25/2017 :  02:10:13  Show Profile
Thanks for the information about new chip.
I have tried a bunch of new chips but still having the same issue.
Even tried 2 different SOP44/DIP40 adapters.
The chip is recognized properly but the data programmed passes thru.
I've been using this programmer to burn regular Eprom mainly with no problem. I
vendest
Posted - 02/01/2017 :  08:07:12  Show Profile
Managed to program successfully a MX29F800TMC-90 with TOP3100.
The programmer might just not be compatible with MX29LV160TM.
