 GQ-4X MX25L6406 will not write
tvshop2
Posted - 01/25/2013 :  07:31:45  Show Profile  Reply with Quote
Hello, I am trying to write my bin file to this blank MX25L6406 chip. I am able to read the old chip just fine. I have performed the blank check on the new chip (it passes fine). When attempting to write to the new chip it hangs up on write. I have tried another new eeprom with same results. I am using Windows 7. I am also using the external 9v supply source. I have also tried a different usb cable. I am using the ADP-081 adapter.
Bad_Ad84
Posted - 01/25/2013 :  11:09:00  Show Profile  Reply with Quote
Have you tried changing the speed?
yui
Posted - 02/18/2013 :  15:19:19  Show Profile  Reply with Quote
for me same problem!!
change different speed but problem same,with gq-3x works fine, with new gq-4x allways stop after writing sometimes with 10 % somtimes 85%,tested with same chips with same pc and software,only change programer,any ideas?
Bad_Ad84
Posted - 02/19/2013 :  06:56:23  Show Profile  Reply with Quote
try adding a 100nf capacitor between VCC and GND on the chip
yui
Posted - 02/19/2013 :  14:05:02  Show Profile  Reply with Quote
thank you problem solved for id check,but writing same problem stop writing at 3 or 15 %
Ready
H/W Re: GQ-4X Re-2.00(SW Re. 6.21)
USB Driver Re.2.0
Software Re. 6.21
DEVICE MX25L8005M2
Edited by - yui on 02/19/2013 14:14:38
Posted - 02/21/2013 :  20:04:08  Show Profile  Reply with Quote
Change to another chip and try. Sometime the chip is bad. Also, try a slower speed.
