 GQ-4X and PIC12F629 verification problem
geoanas
Greece
Posted - 03/01/2014 :  21:44:50  Show Profile
Hi
I have a GQ-4X programmer and software ver.6.29 installed on my computer.
I tried to program some PIC12F629 chips and despite all my efforts every single one fails on verification process.
What shall I do ?
Posted - 03/02/2014 :  11:43:14  Show Profile
Can you get chip ID correctly?
Did you erased the chip and passed the blank check?
What is your exac error message?
geoanas
Greece
Posted - 03/03/2014 :  13:44:07  Show Profile
Yes I can get the chip's ID correctly
When I erase the chip, it passes the blank check.
When verification process starts, I always get an error with "Configuration VerifyFailed".
Seems that problem is on PIC's Configuration....
Posted - 03/03/2014 :  14:55:13  Show Profile
I think your configuration word has a wrong data.
Can you do a screen copy and paste here for the configuration words tab?
The chip should be OK.
geoanas
Greece
Posted - 03/04/2014 :  08:22:44  Show Profile
Ok ! First one shows the error message and the latter is the configuration TAB after Verification Failure
107.2 KB
81.76 KB
Posted - 03/06/2014 :  19:31:31  Show Profile
It is looks OK.
Try to read the chip and see hat is the CFG value you got. If you got 3FFF CFG value, then the chip should be programmed correctly. There is a software bug here.
