 help me 93lc86c
tani
France
Posted - 06/29/2010 :  23:32:04  Show Profile
hi,
can you tell me if you need the adapter 9v 93lc86c to read a chip on a circuit?
WHAT IS THE CONNECTION TO THE CHIP, I cable SOIC, thank you
merci
Posted - 07/01/2010 :  09:47:33  Show Profile
You do not need any adapter on this chip.
It has different connection on different board. You need to try and find a way to connect it.
Mostly, if you can power the board on, you do not need to connect the Pin 8 VCC pin.
tani
France
Posted - 07/19/2010 :  13:50:34  Show Profile
hello
help me
I can not read a circuit chip 93lc86c
YOU CAN NOT TURN THE POWER CIRCUIT
is for a car counter?
CAN YOU GIVE ME THE ORDER OF CONNECTING THE CHIP ON SOIC8 3M?
I possess the GQ4-x wiht soic 3m
merci
Posted - 07/19/2010 :  16:53:45  Show Profile
If you can not power up the circuit, then most likely you are unable to read the chip. That because the programmer does not have enough power to power youe circuit. Anyway, you can try it.
