| Author |
Topic  |
Marcelo Disconzi
Brazil
6 Posts |
Posted - 09/08/2016 : 21:26:14
I'm trying to write this IC using a GQ-4X with APD 082, but without success...
AMD29F032B -90EC 0833DBM H
ID is checked OK (0141), but, the error appears at start of process,0% always, in some cases, I try to erase first, and the erase ends less of one second, something wrong occurs i guess.
I'm trying some ideas, previously discused here, how use a 100nf Z5U cap, or a 2k resistor, but, in both cases, the problem remain. I try too, write lowest (-2), and writes, but at verifies, nothing was write.
If someone can help... |
| Reply #1
2949 Posts |
Posted - 09/11/2016 : 23:13:48
You chip is not erased.
The chip must be erased before write new data.
Check the chip pin contacting with programmer. Also, change to another chip to try if possible. |
| Reply #2
Marcelo Disconzi
Brazil
6 Posts |
Posted - 09/12/2016 : 08:27:01
Hi ZLM
I have tried more than 4 chips, the problem is the same, I perform the blank check, works fine, but, in some cases, the erase process ends at start. |
| Reply #3
2949 Posts |
Posted - 09/15/2016 : 20:00:19
| Your programmer is GQ-4x OR GQ-4x4? |
| Reply #4
Marcelo Disconzi
Brazil
6 Posts |
Posted - 09/20/2016 : 20:26:03
GQ-4X |
| Reply #5
Marcelo Disconzi
Brazil
6 Posts |
Posted - 01/18/2017 : 17:22:34
Some idea??
| Reply #6
2949 Posts |
Posted - 01/21/2017 : 19:40:44
Have you try the jumper on ADP-082? V1/V2? Use slower speed? |
| Reply #7
Marcelo Disconzi
Brazil
6 Posts |
Posted - 01/22/2017 : 13:38:59
Yes, I have tried both, if I try to write at any higher speed -2, an error occurs in the first byte, if I try to write at -2, the write arrives at 100%, but, when checking, (3 / 5V) The chip is completely empty, as if there was no recording. |
| Reply #8
Ice Man
32 Posts |
Posted - 03/07/2017 : 08:26:19
I have the same problem. I can't write AM29F016B or MBM29F033C. ID Check is correct with jumper set to V2 and 5V. I'm using ADP-082 with ADP-077 set to TSOP40B.
I try program but every time I get an error about buffer. I erased the ICs but nothing helps. Other programmer (TL866) program them fine so it's not a problem of the IC.
What to do? |
Edited by - Ice Man on 03/07/2017 08:27:08 |
| Reply #9
2611 Posts |
Posted - 03/07/2017 : 08:48:50
| Did you try a slower speed? |
| Reply #10
Ice Man
32 Posts |
Posted - 03/07/2017 : 09:01:15
Tried MBM29F033C at -2 Speed. Program 100%, Verify Fail.
AM29F040B TSOP32 works fine. Everything ok. TSOP40 does not work fine. :( |
Edited by - Ice Man on 03/07/2017 11:45:51 |
| Reply #11
2611 Posts |
Posted - 03/08/2017 : 08:58:15
| Trouble with the ADP-082? |
| Reply #12
Ice Man
32 Posts |
Posted - 03/08/2017 : 09:24:16
Looks like it. But I don't know where/why. Tried Jumper V1/V2. Same results. |
| Reply #13
2611 Posts |
Posted - 03/08/2017 : 09:55:48
| Maybe bad solder joints? |
| Reply #14
Ice Man
32 Posts |
Posted - 03/08/2017 : 10:06:37
Just checked. Everything looks clean. :'( My Programmer is GQ-4X4 with Software 7.11 and USB 3.0 Driver.
Resistors are 2x2.2k and 1x24 Ohm. All work. Diode show 597 Ohm, so they work, too. Maybe 74HC244 is faulty? Is it even needed?
Here is pictures of ADP-082: h**p://share.pho.to/AdX7z |
Edited by - Ice Man on 03/08/2017 10:11:33 |
| Reply #15
2611 Posts |
Posted - 03/08/2017 : 10:13:44
| Maybe you can use the hardware test function of the software to find the fault. |
| Reply #16
Ice Man
32 Posts |
Posted - 03/09/2017 : 10:43:53
| How would I test it with hardware test function? |
| Reply #17
2611 Posts |
Posted - 03/09/2017 : 16:34:19
| You can switch individual pins to trace where it goes wrong. |
| Reply #18
Ice Man
32 Posts |
Posted - 03/10/2017 : 10:04:58
Well, I tried programming with -1 speed, but verify always fails since it doesn't program properly. I don't know how exactly I'd trace the pins as I don't have any pinouts nor would I know what to check. Is the 74HC244 really needed at all?
Perhaps, can someone else confirm that the MBM29F033C, AM29F032 and AM29F016 all don't work to program? Or did someone find a way to program them? |
Edited by - Ice Man on 03/10/2017 10:05:40 |
| Reply #19
Ice Man
32 Posts |
Posted - 03/15/2017 : 06:02:06
I have the solution: To program 29F033C use an external 9V DC power supply as well while programming! It worked fine for me. Program OK, Verify OK. |
Topic  |
