 MX29LV160T / MiniPro TL866CS
vendest
Posted - 08/08/2017 :  08:31:16  Show Profile
Hi, I'd like to check if anyone here has encountered issues to program a MX29LV160 and MX29F1610 with MiniPro TL866CS?
Drop down list from MiniPro Programmer Software does not include MX29LV160 SOP44 (only TSOP48) and does not include at any MX29F1610.
I've only been successful with burning MX29F800T so far.
Any advice on how to add the missing EEPROM to the list?
125265 bytes
235078 bytes
Posted - 09/15/2017 :  04:09:32  Show Profile
125265 bytes
235078 bytes
You should ask on the manufacturer website.
tewbc
Thailand
Posted - 10/24/2017 :  18:44:17  Show Profile
It can be program with a modified pin 9(A19)/11(WE)/12(Reset) on TSOP48 V.3 adapter along with SOP44 adapter.!! Also you need to select chip as "MX29LV160T @TSOP48" on MiniProv660.
h**p://www.mx7.com/view2/AcnznegtxjqMtwc9
h**p://www.mx7.com/view2/AcnGzTtMPpoe7BL5
Edited by - tewbc on 10/24/2017 19:13:57
vendest
Posted - 11/10/2017 :  08:59:55  Show Profile
Thanks for your reply, I am currently using both adapter TSOP48 V.3 and SOP44 but I do not quite understand what kind of modifications I should do on the 3 pins you mentioned.
The pins mentioned match with TSOP48 package while I need to use SOP44 package.
Can you please elaborate?
Thanks,
Vendest
