 EN29LV800BT-70 (not ID)
joni12341
Ukraine
Posted - 05/28/2018 :  00:27:40  Show Profile  Reply with Quote
hi
EN29LV800BT-70
add in device list Name="EN29LV800BT",ID="1CDA",Class="29LV800T",Category="FLASH",MFG="Eon Silicon",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position,29FXXX.";
in soft celect EN29LV800BT
tap the ID - and NO ID - DEVECE ID INFORMATION 4706
IC IS NOT LOCKED
adapter TSOP 48 8bit mode
pins selected j4=off j2=29F j1=5v
the ic is working (the laptop with him working - problem wit bios password)
please help
laptech
Posted - 06/13/2018 :  06:12:32  Show Profile  Reply with Quote
Maybe the chips is not connecting to the adapter pins properly. I have just tried a near identical chip in my GQ and you can see by the screen shots it works OK.
NOTE: My chip is slightly different to yours, mine is 29LV800CT hence why chip ID is different.
596902 bytes
473298 bytes
Laptronics UK LTd. Specialist motherboard repair.
davebb
Posted - 06/18/2018 :  08:17:29  Show Profile  Reply with Quote
Hi I had a problem with writing, but could read ok, no id,
I found the problem was with the soldering on the ZIF socket inside the programmer, use a multimeter
test all pins from the zif to the sockets that plug on to the pcb programmer pins,
Dave
Posted - 06/20/2018 :  03:34:40  Show Profile  Reply with Quote
Dave
No need to open up the programmer to test it, you can simply use the software...
