 Please Add 16F1788 support -popular
davesaudio2 Posted - 09/11/2016 : 07:23:37
Seeing this chip in more shared projects, please add support.
Dave
ZLM Posted - 11/14/2016 : 22:50:16
has some difficulty to get it work. But I will try again later soon.
davesaudio2 Posted - 11/14/2016 : 05:37:16
Any news on this?
ZLM Posted - 09/26/2016 : 20:36:12
OK. You can send 1 or 2 chips to:
GQ Electronics LLC
5608 Delridge Way SW,
Seattle,WA 98106
davesaudio2 Posted - 09/21/2016 : 04:34:45
ZLM-Any progress? Shall I have Digikey sent you a couple of chips?
Dave
davesaudio2 Posted - 09/16/2016 : 08:00:27
pickit2 with some mods will write but (on my test of today) stuck on config verify
some info here- https://sourceforge.net/p/gcbasic/discussion/629990/thread/ca49b406/#4685
(In case this provides some clues)
davesaudio2 Posted - 09/16/2016 : 06:00:31
Chips are installed correctly.
Tried 2 DIPs and 1 SOIC on ADAFRUIT's DIP adapter.
Does not identify chip.
ZLM Posted - 09/15/2016 : 12:45:34
Can you confirm your chip location? For the 28 pin chip must pin 1 upward and top aligned.
davesaudio2 Posted - 09/15/2016 : 08:07:33
Made the changes
GQ-4X does not read chip ID: unknown device 0000
both DIP and SOIC devices
ZLM Posted - 09/11/2016 : 23:04:01
Try following lines and download the attached .dev files.
Name="PIC16F1782",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP28",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000";
Name="PIC16F1783",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP28",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000";
Name="PIC16F1784",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP40",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000";
Name="PIC16F1786",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP28",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000";
Name="PIC16F1787",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP40",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000";
Name="PIC16F1788",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP28",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000";
Name="PIC16F1789",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP40",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000";
PIC16F1784.zip:
68381
