 Toyota denso 93c56 programming with t48
Author  Topic Next Topic
Bamse82
Posted - 03/21/2026 :  07:07:44  Show Profile  Reply with Quote
Hi guys! Managed to desolder the 93c56 on a broken toyota denso ecu.
I just wan't to practice on this one for a immo off...
I read the eproom, did immo off in toyolex.
But every time I try to program it in XProg it says: "Verifying FLASH... ERROR! FLASH ADRESS 0X000018  Buf_Val: 0x2112  IC_ Val 0x0000 Programming Failed......
Have tried other files I found on the forums with the same eeprom. Same error.
I can reprogram the ori file with no errors...
What am I doing wrong???
This Toyota Yaris is about to buuuurnnn.
EDIT! Unblocked the optinion "Verify after" and it was sucessed. But when I read the eproom once again the ori file is still in there.
Is this a joke?
Posted - 03/21/2026 :  13:27:34  Show Profile  Reply with Quote
Is this a joke?
What is the complete part number?
Bamse82
Posted - 03/21/2026 :  21:58:20  Show Profile  Reply with Quote
Ra57/93c56 on the eeprom. The ecu is a 27036-1152 [PCB]
Posted - 03/22/2026 :  08:00:18  Show Profile  Reply with Quote
Chip is probably damaged.
Bamse82
Posted - 03/23/2026 :  02:27:55  Show Profile  Reply with Quote
But I could read it 7 times with no problems? Could also program it with ori data
Posted - 03/23/2026 :  07:25:44  Show Profile  Reply with Quote
Can you successfully program other 93C56 chips?
Bamse82
Posted - 04/07/2026 :  12:54:03  Show Profile  Reply with Quote
Nope. Can't program any 93c56... even ordered blank eeproms but No sir
Posted - 04/08/2026 :  10:11:34  Show Profile  Reply with Quote
Bad programmer?
Bamse82
Posted - 04/08/2026 :  13:15:52  Show Profile  Reply with Quote
Maybe... I use a t48 programmer. But do you think a gq-4x4 will do the job?
Posted - 04/09/2026 :  05:55:06  Show Profile  Reply with Quote
93C56 is compatible with the GQ-4X4 in 8 and 16 bit.
Bamse82
Posted - 04/09/2026 :  09:22:02  Show Profile  Reply with Quote
Ordered a gq4x4. I will report after test
Posted - 04/10/2026 :  05:29:27  Show Profile  Reply with Quote
Yes, please do so.
Bamse82
Posted - 04/12/2026 :  11:15:58  Show Profile  Reply with Quote
Tested with the GQ-4x4 now. Get verify fail on this one too. What am I doing wrong???
Have tested two blank eeproms and two from ecus. Have also tried many different 93c56 versions in the device menu. Tested with different speeds.
And also tested with a solder adapter, clip adapter and a adapter thst reminds of adp-004 which was included from the t48.
Please give me some hope. 3 months on this stupid toyota now and can't get anything to work
Edited by - Bamse82 on 04/12/2026 13:56:38
Posted - 04/14/2026 :  07:48:18  Show Profile  Reply with Quote
Please post a picture of your setup.
Bamse82
Posted - 04/14/2026 :  10:40:34  Show Profile  Reply with Quote
Posted - 04/15/2026 :  08:19:32  Show Profile  Reply with Quote
Did you do a blank check?
Bamse82
Posted - 04/15/2026 :  10:53:02  Show Profile  Reply with Quote
Yes I did a blank check.
Reply #17
Posted - 04/16/2026 :  13:29:32  Show Profile  Reply with Quote
Are you able to erase the chips?
Reply #18
Bamse82
Posted - 04/16/2026 :  20:47:10  Show Profile  Reply with Quote
No i'm not. After erase the same data still appears. I thought if the t48 adapters has different pinouts? Because i'm out of ideas now. Seems that other users have sucessfully read/write those eeproms with both programmers.
   Topic Next Topic
