Active Users: / Visits Today:
PLCC44 ST M27C1024
Note:
To register,
click here
. Registration is FREE!
640 x 480
800 x 600
1024 x 768
1280 x 1024
Basic
Help
Prompt
Format:
Font
Andale Mono
Arial
Arial Black
Book Antiqua
Century Gothic
Comic Sans MS
Courier New
Georgia
Impact
Lucida Console
Script MT Bold
Stencil
Tahoma
Times New Roman
Trebuchet MS
Verdana
Size
1
2
3
4
5
6
Color
Black
Red
Yellow
Pink
Green
Orange
Purple
Blue
Beige
Brown
Teal
Navy
Maroon
LimeGreen
Forum Code
is ON
[quote][i]Originally posted by jaxone[/i] [br]Hello. I am having a problem writing this M27C1024 chips. Bought 10 NEW EMPTY ones and I can read the original with the ADP-054. When I try to flash the empty ones I always get error like : Write failed, Address=0x000200, Buffer=0xB1 Device=0xFF Write failed Tried another chip, same error. Cleaned all contacts. Tested programmer for voltage etc. And as I said, I can read the original just fine. Blank check does not help for s%%% as it tells me chip is blank even without the adapter attached to the programmer. Can see many people had problems with this chips but nobody posted a solution. Any help appreciated. [/quote]
T O P I C R E V I E W
jaxone
Posted - 03/27/2016 : 15:36:55
Hello.
Write failed
2 L A T E S T R E P L I E S (Newest First)
Posted - 03/28/2016 : 22:16:25
Looks like the address A9 has problem.
Check A9 pin voltage while reading the chip at slowest speed. The A9 pin should have voltage changing while reading.
The A9 pin you can find from software menu Test H/W-> Test H/W pinout:
57012 bytes
Posted - 03/27/2016 : 15:58:48
http://www.mcumall.com/forum/uploaded/zlm/201251512716_M27C1024_2048_4096.jpg
Generated in 0.04 sec.
