 Can i program a 29f800 with a 16 bit adapater?
selmar Posted - 11/05/2007 : 02:55:31
Hello, Today I received the programmer GQ-3X R 1.00 WITH ADPATADOR TSOP48 16 BIT ZIF Adapter for Willem Programmer.
Can i program a 29f800 or a 29lv160 with this adapter ??
When i push ID with a 29f800 in the adapter, the device id is diferent, the response is BF03 and it should be 0158.
Sorry by my English, so I speak only a little
ZLM Posted - 01/11/2014 : 09:35:00
Try this:
Name="A25L512",ID="373010",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="65536";
Name="A25L010",ID="373011",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="131072";
Name="A25L020",ID="373012",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="262144";
Add those lines into devices.txt file.
Let me know if this works.
repairs Posted - 01/11/2014 : 05:58:35
hi dudes,
i've gq-4x usb programmer, but its not support this amic (a25l010c)please anyone can help me
ZLM Posted - 12/25/2007 : 19:13:26
The chip need to be erased before write. Also do a blank check before write.
andres Posted - 12/15/2007 : 10:24:21
Hello I have just received the programmer GQ-3X Re-1.00 with adapter for the memory AT49F040-12TI, I can read the information of the memory but he/she doesn't allow to fade it write it again. you could you explain to me that I should make. thank you
selmar Posted - 11/07/2007 : 16:33:02
O.k. Thanks for the answer, I hope that will be implemented with any new release.
Thank you again for your quick response.
ZLM Posted - 11/06/2007 : 23:41:18
Yes. the parallel willem software supports 29LV160 on 16Bit TSOP48 adapter.
The True USB Willem hardware is supported 29LVxxx flash on 16Bit TSOP48 adapter. It is just a matter of software not implemented yet.
selmar Posted - 11/05/2007 : 15:37:14
Hello, the TSOP48 16 BIT ZIF Adapter for Willem Programmer work fine with these flash in a willem parallel programmer 0.97ja i checked this .Why dont work with the USBPRG program ?
This adapter work fine with these flash in a willem eprom programmer parallel but donīt work in the gq-3x r1.00 i donīt understand this.
Best regards.
ZLM Posted - 11/05/2007 : 09:20:00
For the TSOP48 chip 29F800 or 29LV160, the TSOP48 8bit adapter is needed. The 16 bit adapter will not work.
The 8 bit adapter see ADP-003:
www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3102
