| T O P I C R E V I E W |
| LMQT |
Posted - 01/14/2008 : 13:17:33 Hi,
Is it possible to read and write a 2532 chip with the "True USB" ? Same question with a 2508 chip please  |
| 14 L A T E S T R E P L I E S (Newest First) |
| ZLM |
Posted - 08/05/2008 : 13:58:17 It should work if only read it. Not sure why. |
| LMQT |
Posted - 08/02/2008 : 07:06:20 It doesn't works :( No more ideas ? |
| LMQT |
Posted - 05/22/2008 : 12:48:52 OK I'll try that. Thanks a lot for your help :) |
| ZLM |
Posted - 05/11/2008 : 22:05:59 Add this line to devices.txt:
Name="TMS2508",ID="XXXX",Class="2716(25V Vpp)",CodeSize="1024",Category="EPROM",MFG="TI",RVPP="5V",Message="Apply external power."; |
| LMQT |
Posted - 05/08/2008 : 07:52:24 Please, help me  |
| LMQT |
Posted - 04/22/2008 : 08:15:25 Thank you EzoSat
Now, is someone able to help me to parameter the software in order to read and programm this kinf of PROM please  I don't have idea at all to do that  |
| LMQT |
Posted - 04/13/2008 : 02:04:07 quote: Originally posted by ZLM
I think the 2508 to 2532 is not read compatible.
The programmer should be able to read it. Do you have datasheet?
No, not found  |
| ZLM |
Posted - 02/08/2008 : 14:26:19 I think the 2508 to 2532 is not read compatible.
The programmer should be able to read it. Do you have datasheet? |
| LMQT |
Posted - 02/07/2008 : 13:51:42 quote: Originally posted by ZLM
GQ-2X only read the 2532. But GQ-2X is able to read,write the 2516.
No way to read a 2508 (2532 pin compatible) at all  I just got "FF" all along the memory.
I've also tried an adaptator like this picture to read it as if it were a 2732, but it won't works :
And I'm sure the ship is fully functionnal because it cames from a calculator who works perfectly in my car.
I've tried with a NS27S181 and an AM27S181ADC (2508 compatibles) : not good.
Is it normal that for 2532, 2732 and almost any PROM of this kind, the software tell to put the same switches on (1, 6 and 8) ? |
| andres |
Posted - 01/18/2008 : 13:04:51 Is it possible to read and write a MC68HC908QY4 chip with the "True USB" ?
| LMQT |
Posted - 01/18/2008 : 09:33:55 OK, thank you. So read-only for 2532.
But what about my old poor 2508 ? :) |
| ZLM |
Posted - 01/17/2008 : 14:15:07 GQ-2X only read the 2532. But GQ-3X is able to read, but write only works on some batch chips. |
| LMQT |
Posted - 01/17/2008 : 11:01:44 Thanks.
"no write on GQ-2X" but is reading OK ? |
| werejag |
Posted - 01/14/2008 : 21:18:53 This device is under testing, no write on GQ-2X and write is not garranted on GQ-3X.
says in the software for 2532 |
