 Is there anybody who can explain this picture?
sprit01 Posted - 03/03/2009 : 08:49:51
50.12 KB
I figured out Options and Oscillator Select but don't have any idea of "Number Settings"
Can anybody knows what the number settings means?
Thank you
sprit01 Posted - 03/05/2009 : 05:02:27
That wasn't problem it was from different portion..
When I change the portion of 3fe, the writer says "it's done". however, when I read it back from the chip, it wasn't burned
the data I want to put is "347c"
ZLM Posted - 03/03/2009 : 23:52:14
What is your means "it is not working"? Th ID is no part of yor code, you need to set it manually.
sprit01 Posted - 03/03/2009 : 11:59:34
12f675
I read the datasheet of 12f675..
According to this, Only the Least Significant 7 bits of the ID locations are used
So, I set "00 00 00 FF 00 FF 00 FF" on "00002000"
However, it's not working
am I wrong?
ZLM Posted - 03/03/2009 : 11:34:58
You need to read the datasheet of your chip.
What is your chip part number?
