 Willem & Parallel-Usb-Adapter
Zak McKracken Posted - 07/15/2009 : 00:11:32
Hi guys
I recently bought a Willem programmer PCB5.0 from sivava.com. When I connect it to one of my laptop which is still equipped with a parallel port it is working fine. As software I use WillemEprom or WinPic800. Mainly Im using the thing to program a PIC via ICSP.
On my main laptop there is no parallel port anymore, so I got myself a USB-parallel & serial interface (from Z-Tec). When I hook everything up, the VPP led on the willem board lights up instantly and wont go out. Neither WillemEprom nor WinPic800 is recognizing the programmer. I did a loopback check on the parallel port which worked out fine though. Is there anything I could try to do to make it work?
Thx,
regards
Zak
Bad_Ad84 Posted - 07/16/2009 : 02:41:35
pcmcia should work fine
ZLM Posted - 07/15/2009 : 17:17:42
not sure. You can try it.
Zak McKracken Posted - 07/15/2009 : 16:19:02
thx, thought so...
how about a PCMCIA-parallel card, do u think that would work?
sooner or later Ill have to get myself a USB-ICSP I suppose...
ZLM Posted - 07/15/2009 : 06:47:13
The parallel willem programmer only works on real parallel port, not the USB-parallel adapter.
Bad_Ad84 Posted - 07/15/2009 : 03:38:16
they dont work with most things.
