 GQ-4X to flash BIOS onto SST25VF080B
3baby Posted - 08/01/2009 : 23:24:00
Hi there,
i have a ECS X58B-A2 mainboard thats had a bad BIOS flash, the board has an 8 pin SPI header, i am wandering if the GQ-4X will be able to program the SST25VF080B EEPROM on the board? also ifso.. what cables are required to do so.
thanks in advance.
ZLM Posted - 08/11/2009 : 10:07:48
MB picture:
ECS X58B-A2
27.51 KB
3baby Posted - 08/11/2009 : 00:36:21
Programmer arrived today!! and the boards living once again.. the Programmer is Worth Every penny!!
BTW the EEPROM i had on the board was SST25VF016B.. little hard to see as the "16" was half scratched off.
ZLM Posted - 08/02/2009 : 06:59:55
The GQ-4X supports SST25VF080B EEPROM.
If your motherboard has SPI header, then it should be able to re-program it on board.
If you have jumper wires, then you may directly connect the motherboard SPI header to the programmer ZIF socket.
OR you can use following items:
1. http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4244
2. http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4366
3. (optional)http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4310
see:
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=1434
