T O P I C R E V I E W |
AG42 |
Posted - 10/02/2009 : 18:11:52 Hello I just got the GQ-X4 and I must say I'm very happy with it. I have a question though. Can it read and program the Intel AB28F200 flash EPROM? I was looking into device support and there are some similar EPROMs but not this one. I will try to upload a picture of it.
Thanks.
AG42
 164.18 KB |
7 L A T E S T R E P L I E S (Newest First) |
ZLM |
Posted - 09/29/2010 : 17:28:43 Both should be OK. But to confirm its read OK, you need to have either original data checksum, or write the data into another chip to do a testing in machine. |
brchip |
Posted - 09/29/2010 : 08:51:39 Thank you. I could read it as PA28F200BX-B but how can I know if my reading is correct? Which one should I use: AB28F200BX-B or PA28F200BX-B? |
ZLM |
Posted - 09/28/2010 : 20:47:06 Yes. You can try AB28F200BX-B. |
brchip |
Posted - 09/28/2010 : 16:28:15 Hello, what about AB28F200BRB80, what device should I choose to read/write? Can I use the same as above? PA28F200BX-B? Thank you! |
AG42 |
Posted - 10/15/2009 : 15:58:48 I got the adapter and using the setup by ZLM I had no problem reading, erasing and programming this chip.
Thanks ZLM |
AG42 |
Posted - 10/03/2009 : 10:24:56 quote: Originally posted by ZLM
Select PA28F200BX-B*PSOP44.
Thanks ZLM. I'll try that and post results.
AG. |
ZLM |
Posted - 10/02/2009 : 23:15:20 Select PA28F200BX-B*PSOP44. |
