 Checksum error reading HexFile
Necrosaro420 Posted - 01/20/2010 : 17:24:29
Is there a way to turn this message off??? I know the files I use are good, I have used them several times before. But now on 2 different pc's I try to load files up and it gives me "Checksum error reading HexFile" and it wont load the files to let me burn them. These are 4 meg files using M29F032d Using v5 software. Thanks
ZLM Posted - 01/22/2010 : 10:21:29
Looks like a bug. We will check the software.
Necrosaro420 Posted - 01/22/2010 : 04:29:50
Heya, if I go to file>open and browse to the file this happens. But then directly after that, if I go to File and then scroll to the bottom of recent opened ones and pick the exact same file, it does not do this, and it burns fine. Sounds liek a bug in the prog IMO
ZLM Posted - 01/21/2010 : 21:36:08
Then the hex file may be not a good one. Or you can send it to me check it.
Another way is to convert your hex file to bin file use the convertor. Then load the bin file.
Necrosaro420 Posted - 01/20/2010 : 17:26:29
BTW, one pc is using Win 7 Pro, other is XP Pro
