 GQ-4x and SST25VF080B problem
finla Posted - 02/18/2010 : 06:40:43
Hello,
GQ-4x can read the chip but didnīt erase the chip. I tried so many time but nothing empty. Blank Checking Gq-4x said " Device blank check failed at address 0x000000, Read= 0x91."
I tried to write new bios-file. GQ-4x worked fine with red-led, after writing without problems but verifing failed, I read the chip again and nothing changed in the chip.
Please helps !
finla Posted - 02/18/2010 : 11:44:53
Thank you !
ZLM Posted - 02/18/2010 : 07:50:51
First of all, you should be able to get corrct ID.
The chip need to be erased before write new data.
Do a blank check before write new data to make sure the chip is blank.
