 Support F25L008a
br1 Posted - 03/02/2010 : 11:51:13
Is the F25L008A –50DG 50MHz 8 lead SPI bios chip progammable with the GQ-4X?
Datasheet:
www.esmt.com.tw/DB/manager/upload/F25L008A.pdf
How do you know whether a chip is compatible (Supported Device List) or when a device entry can be added to devices.txt?
Thanks.
ZLM Posted - 12/18/2013 : 16:02:05
ID="8C2014", when you click the ID button he software should report: "F25L008A" found.
Alex113 Posted - 12/18/2013 : 09:48:31
the chip has been erased, but I can not write chip, since the chip F25L008A its correct ID and present the program to read it.?! What is your ID in this chip ..?
thanks
ZLM Posted - 12/16/2013 : 19:30:40
Can you erase the chip?
If you can erase the chip, then the chip is not protected.
Also, you need to get correct ID and read the chip correct.
Alex113 Posted - 12/16/2013 : 12:27:39
I used the icon "Lock", it does not work to remove protection ....?!
I am puzzled ...!? the microchip has been deleted, but you can not write
thanks
ZLM Posted - 12/14/2013 : 23:00:56
Click on "Lock" icon, it will open a chip security window.
Alex113 Posted - 12/11/2013 : 14:38:35
I have problems with writing F25L008A!? the program after verification of writing is in error, it has write protection ...!? I can not remove the write protection ...?
help me please ..!
ZLM Posted - 03/06/2010 : 11:33:59
Try to add following line into devices.txt file:
Name="F25L008A",ID="8C2014",Class="W25X10",Category="SERIAL_EPROM",MFG="ESMT",Vcc="3.6V",CodeSize="1048576";
