 How to flash a bios image on a MX25L8005PC
yotka Posted - 05/02/2010 : 00:58:41
Hello all.
I am a proud new owner of the GQ-4.
Recently I killed a motherboard by using the manufacturer's windows flash utility.
It has a socketed MX25L8005PC.
Motherboard model: ECS P45T-A2R
I have been trying to get it up and running but ID Check/erase/Blank check/writing/verifying successfully do not seem to be able to get the motherboard up an running.
The most it does is power up, fans spinup for about a second, before shutting down again.
Does anyone have any ideas, regarding SPI chips?
File and device offset are all default, at zero.
yotka Posted - 05/10/2010 : 16:19:50
Ok, all good now.
The Chip programmer worked flawlessly.
Verified that the motherboard is dead.
The EN25F80 works as a direct replacement for the MX25L8005PC, while doing my tests.
Thanks for the help!
yotka Posted - 05/02/2010 : 19:41:13
I have the same conclusion.
Will try ECS's tech support and see if I can get a bios chip sent, provided its not too expensive.
ZLM Posted - 05/02/2010 : 08:54:39
looks like your BIOS data file is not correct one.
If you can find a working motherboard, then copy it to your BIOS chip.
