 27C800's quit burning....
Necrosaro420 Posted - 08/16/2010 : 18:54:08
My M27C800's used to burn fine, but they all of a sudden quit programming. The adapter is fine, as I can burn M27C160 and 322's just fine. I have several 800's from 3 different places. I have the True USB v3
Cochobot Posted - 08/31/2010 : 11:09:51
I have the same problem, lucky me that old burner worked again.
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=2888
Necrosaro420 Posted - 08/30/2010 : 10:45:05
anyone?
Necrosaro420 Posted - 08/24/2010 : 13:15:21
Same error message except Buffer=0xFE using 160 setting trying to burn 800
Necrosaro420 Posted - 08/22/2010 : 17:59:16
New software has same result. Also tried new software with a different pc, same deal. Verifys blank, but will not program. Though using the same adapter 27c160 and 27c322 works fine
Necrosaro420 Posted - 08/22/2010 : 13:35:34
Im going to try the updated software, have been using the previous version, later tonight and see if that will take care of it.
Necrosaro420 Posted - 08/20/2010 : 20:09:39
What I mean by quit, is they used to work fine...but they no longer program, and I have received chips from several different places and they still wont burn. Here is the message im getting:
Write failed, Address=0x000002, Buffer=0x02 Device=0x00
I have verified that they are blank
ZLM Posted - 08/17/2010 : 01:12:30
"quit programming"??
what is the error message?
