T O P I C R E V I E W |
psxboxmod |
Posted - 08/25/2010 : 06:22:25 Hello, I can not read with programmer GQ-4X an EPROM 29F010B I have this error: What can I do?
 108.73 KB |
ZLM |
Posted - 08/25/2010 : 08:00:12 Check adapter. |
psxboxmod |
Posted - 08/25/2010 : 06:39:42 quote: Originally posted by ZLM
check:
1. chip pin contacting problem.
it's ok
2. chip chip pin 1 location to make sure you have placed chip in correct orientation.
it's ok
3. check the adapter has no soldering problem. It is best to use a multi-meter
it's ok
4. change to another chip.
with the first chip i've error "FFFF" with second chip error "8080"
ZLM |
Posted - 08/25/2010 : 06:34:00 check:
1. chip pin contacting problem. 2. chip chip pin 1 location to make sure you have placed chip in correct orientation. 3. check the adapter has no soldering problem. It is best to use a multi-meter. 4. change to another chip. |
