T O P I C R E V I E W |
flashcoder |
Posted - 12/01/2010 : 18:33:57 Normal FWH/LPC+ adapter ADP-030 is missing DIP sockets and some other components for TSOP adapters which are offered in Professional FWH/LPC+ adapter set ADP-057. Now, I have this Normal version and suddenly need the TSOP capability, I can just solder in the missing parts and it will work. I could, of course, just order the ADP-057 set but I already have that TSOP adapter and besides why waste a working adapter if you can just upgrade it right? :) But there is a problem with those two missing transistors, I dont know if they are the same as other two on this Normal FWH/LPC+ adapter, those are PNP transistors S8050 pdf1.alldatasheet.com/datasheet-pdf/view/33773/WINGS/S8050.html
Can someone confirm what transistors are used for TSOP part of the FWH/LPC+ adapter?
Thanks!
4 L A T E S T R E P L I E S (Newest First) |
flashcoder |
Posted - 12/14/2010 : 20:40:34 Anyway, I already upgraded it with the missing components, it was too easy to resist the DIY upgrade :)
 20.49 KB |
ZLM |
Posted - 12/04/2010 : 20:41:00 Your adapter must be Re2.0 or earlier version.
But it should work fine for most of chips. You do not have to install those missing component. |
Bad_Ad84 |
Posted - 12/03/2010 : 08:53:38 All 5 transistors are S8050 |
Bad_Ad84 |
Posted - 12/02/2010 : 02:27:32 I can check mine later |
