 S29GL064N90TFI040 programming
nikiforospav Posted - 01/21/2011 : 09:19:23
is it possible to program this chip SPANSION S29GL064N90TFI040 with the GQ-4x and which adapter do i need to do that?
what is the difference between 8bit and 16bit
ZLM Posted - 02/24/2011 : 12:40:45
Tested on S29GL064N90TFI040 with a A22 connection. It can ID, read, write, verify, erase, blank check correctly.
Using this device line:
Name="S29GL064N90TFI040",ID="017E",Class="29LV320T",Category="FLASH",MFG="SPANSION",CodeSize="8388608",Adapter="ADP-003 With MOD",VCC="3.6V",Message="Set the adapter to 5V, 29F jumper position. Using ADP-003 MOD 01";
Bottom side look of ADP-003:
86.91 KB
benaknoun Posted - 02/22/2011 : 15:39:15
Based on the information from EZoSat, it should work with this adapter. The adpter has same circuit as the adapter used in EZosat testing. I can give you a picture on how to add the A22 on this ADP-003 adapter for S29GL064N90TFI040.
yes please about picture, i need to program/read AM29LV640ML
i have GQ-4X
thanks
ZLM Posted - 01/24/2011 : 20:28:53
nikiforospav Posted - 01/23/2011 : 23:03:27
thank you very much for the info's, but i am a little bit notice and i don't understanding it very well!
if i buy this adapter http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3102 and the gq-4x and add the line in the device.txt can i manage to programm the chip?
thanks again!
