 SST49LF040B
brunoxghx Posted - 10/05/2011 : 15:27:06
I don't really have a problem...
I had problem with flashing SST49LF040B.
The chip wasn't correctly detected I didn't know why. The voltage listed in the software wasn't correct. I changed it from 12V to 3.6V.
3.6V is the correct voltage. After I changed the voltage in devices.txt, everything was perfect.
I suppose someone will change the default value of devices.txt .
Bruno
ZLM Posted - 10/06/2011 : 09:48:01
Thank you for your information. I will change it later.
