 Help reading ATMLH842
tvshop2 Posted - 09/20/2012 : 07:06:34
Hello, Just purchased a GQ-4X programmer. I am a newbie. I am needing to copy a EEPROM. The generic # is ATMLH842. I can not find a datasheet for it. It is an 8 pin surface mount IC. It uses a 3.3V supply. I have tried choosing a couple different devices using a 3.3V supply but have not had any luck. Can anyone help me. Thanks much.
tvshop2 Posted - 09/21/2012 : 14:12:21
Thanks, found the datasheet. It is the same as AT24C16. The 842 is actually the date code.
Bad_Ad84 Posted - 09/20/2012 : 22:39:05
24C256 should be the right one.
