 Problem Burning PSOP44 - Please Help!
Pikointeractive Posted - 06/11/2013 : 14:09:24
HEllo I just got my PSOP44 adapter from the site for my GQ-4X
I am trying to program 2 chips but they won't ID
First we have
MX29LV320MTMI-90G
This one was easy to find a compatible device on the list;
the MX29L3211; I inquired to the support staff and they sent me this to add on my device list.
Name="MX29LV320MTMI*PSOP44",ID="C2A7",Class="MX29L3211",CodeSize="4194304",Category="FLASH",MFG="Macronix",Adapter="ADP-019 V3",VCC="3.6V",RVpp="5V",TempUnprotect="Yes,False",Platform="GQ-4X",Message="Set the adapter to 5V jumper position. Jumper on 29L3211 positions";
Added it, chose it, but the Chip won't ID. I already tried 3 different ones.
Second,
We have this chip:
LE28DW3218AM - 80
This one I haven't been able to find a datasheet online! It is driving me crazy! it is PSOP 44 as well.
Any help is greatly appreciated, the Second one is very urgent for me to re-program!
Pikointeractive Posted - 08/27/2013 : 16:24:15
bump,
I noticed a pattern on the programmer. I think it went bad.
If I am burning a flash chip, (am29f016b) and then switch to MX29LV32's it won't write. I have to disconnect, restart, etc SEVERAL times before it can work.
If I get a writing error, all the chips I try after the one that gave me the error, will give me errors as well. If I get an error with example.bin file while trying to write it, and even if I turn off the pc etc, if I open the same file on the same directory it will give me the same error on every chip I try.
It seems that my programmer is faulty, or the quality of GQ-4x programmer is not very good.
Im not sure if it is software related or hardware related,
Any thoughts?
Pikointeractive Posted - 08/22/2013 : 19:49:53
Having tons of problems 1 out of 5 chips burn successfully I been burning them choosing the MX29LV320CT/CB... but like a said 4 out of 5 games fail to write.
ZLM Posted - 06/28/2013 : 13:41:46
check your chip pin contacting. Most of them are caused by poor pin contact.
Pikointeractive Posted - 06/24/2013 : 17:24:49
Weird.
I was able to do everything, I even wrote a couple of chips successfully.
Then all of the sudden, Writing bar won't move.
I can erase, verify, blank check, etc etc, but I cant write.
Pikointeractive Posted - 06/24/2013 : 13:27:28
works now!
ETA - Is not working now.
ZLM Posted - 06/12/2013 : 23:05:48
Try this:
Name="MX29LV320MTMI*PSOP44",ID="C2A7",Class="29LV320T",CodeSize="4194304",Category="FLASH",MFG="Macronix",Adapter="ADP-019 V3",VCC="3.6V",RVpp="5V",TempUnprotect="Yes,False",Platform="GQ-4X",Message="Set the adapter to 5V jumper position. Jumper on 29L3211 positions";
